Fenix sells 21700 batteries with built in charger via USB-C plug built right into the battery. I am wondering if the USB plug is 2-way, where I can use it to charge the battery itself, and then use it to charge another device that uses a USB-C plug.
I couldn't find anything in their site. I've had a TS2 from Thrunite, and it works just like you are describing. However I think you can only charge it via the usb-c port. It's out of stock right now, but other vendors might have it.Fenix sells 21700 batteries with built in charger via USB-C plug built right into the battery. I am wondering if the USB plug is 2-way, where I can use it to charge the battery itself, and then use it to charge another device that uses a USB-C plug.
Yes, on the thrunite.Thanks, so the usb-c port is bidirectional? I guess I'll email fenix and ask them, it would be nice to have a minimalistic power bank
