Vermonter73
- Joined
- Jul 25, 2006
- Messages
- 335
Can I direct drive 4 Crees in series from 12V? :thinking:
Actually...if your 12V power supply is a car electrical system (read: alternator run by engine)...If your 12v power supply is a car battery - Assuming the battery is in good condition, you should be actually working with 13.8 - 14v.
That's ballpark forward voltage for 4 series connected Cree's.
A car batteries voltage won't sag at all at 1A current draw - So I recon you ought to get a decent drive current (perhaps not a full amp...but something approaching).
What have you got in mind?
Tim.
I have been playing around with crees aand PSUs for a while. Have run 3 crees from 12V and 10V psu, and I couldnt tell that much difference by my eyes.
I have measured currents with different PSUs, now my question is this:
If my measured current is 1A even with the 10V psu (for 3 crees in series), does it mean the LEDs are performing at their maximum? ie can I judge the performance just by measuring the current?
Sounds like something I have been tryin to get to for some time now. I want to add led backup bulbs to my ride and was thinking of the possibilities. Only prob if used in series is if one fails the other 2 go as well correct?. and is there a work around short of parallel?.
ThanX for and suggestions.
X..
