i am the one that suggested that a cooling fan might not be the best thing to put on these chargers that are "calibrated to work without one".
ya see the ammount of change of the voltage drop and all, is a time/quantity thing, if the battery doesnt heat (as much) the battery doesnt v-drop as much, and it could cause missed termination.
NOT because you cant make a charging alogrythm that works with a fan cooling, but just because the unit isnt designed with a fan in mind at the time.
so here is the basic idea and logic (which might be totally wrong, but thats how it seems to me).
at the end of the charge for the battery, the cell goes into a overcharge state, Temperature rises, Pressure rises, and the voltage drop, IMO this is BECAUSE the battery is starting to get damaged, its not taking the charge, and HEAT is being expeled instead of the energy going into chemical changes. the heat and pressure (probably due to gas) causes the chemicals to change the resistance or something, whatever it causes an Anomaly.
so which comes First? the Heat, the temperature , or the pressure, or the overcharge state?
Well who cares which came first
the problem is if you change that somehow , then the computer will not see the MINOR change in the battery, in the time it allots for doing that, and it will not terminate properly.
BUT , if the pressure didnt rise, and the temperature didnt rise, and the Voltage Didnt drop, DID the battery even REACH the overcharge state?
well the battery IS still fully charged, your just dissipating the HEAT off the battery, the energy going in that is still no longer being "stored" in the battery, its just pouring out as heat, and your dissapating that heat off of it.
i think of it a BIT like a teakettle boiling, it probably isnt that way, but the pressure rises , when the temperature (from the heat) gets to high, and the battery internally changes. if you cool the teakettle it will never whistle.
analise:
1. did you get a Voltage drop that the computer can see? NO cause the voltage is still high.
if the voltage was still dropping it could drop as far as 1.3v even with the charge on it.
2. is there a Limit on the total voltage that the unit can put out into the battery ? Yes, the total voltage the curcuits put out is limited. that mean the voltage differential between the battery and the charge voltage will be smaller, because of that at SOME voltage point the current to the battery will be slightly reduced.
3. is the battery being Damaged? #1 question. probably, the battery is still probably overheating in the part tight in the center, where your cooling isnt reaching. your cooling is not internal, there is still heat being produced in the battery, its probably getting very hot (baking) in the center. i have seen the center part of a ni-mhy cell get Brown from the heat.
TERMINATE ON TIMING:
so what can you do? use old timing methods, and stop the entire charge process, when there is nothing but heat comming out.
if the battery IS already fully charged, and your cooling is keeping the v-drop from occuring, WHY would you want to continue the charge till the pressure rises the temperature rises and the battery begins to faulter?
IF you knew it was charged and just not terminating, then terminate it Manually, there is no reason to smoke it so the stupid computer can read an occurance.
TERMINATE ON TEMPERATURE:
Monitor the temperature, when the temperature increases at an increasing level (even with the fan) , then your producing more heat than charge, and its done, terminate the whole process not just the fan.
TERMINATE ON VOLTAGE HIGH
when the voltage reaches a specific HIGH point, the charge IS basically complete, if you terminate the charge anytime it reaches 1.50V this would be charged for most good modern batteries. bad weak batteries with high resistance will go higher than that, better low resistance battereis will not even get that high.
RATE:
Increase the charge rate, in the 15 minute chargers Designed with a Fan, they put SOOO much energy in, that when that energy turns to heat, Even the fan can not remove the heat.
If your not getting terminations, and have a very low rate, then increase the rate, so a visable occurance occurs. of course with the risk of causing even more damage if it still does not terminate .
COOLING:
Decrease the flow of the fan, dont try and remove ALL the heat, so the damage is still done, so the teakettle still boils, problem is you cant recalibrate the computer to detect what now might be a Slower voltage drop.
the computer needs to see the battery faulter in a Time/quantity reduce this time or the quantity and the Present charger that your working with will not work right.
in there there is no Answer, only the puzzel itself.
the built in temperature sencors on most this stuff are not "connected" to the battery enough to be usefull in a temperature termination, they are only good enough to reduce a total disaster, and any cooling, even say putting it outside in the snow, would render the already almost useless temp seoncors , completly ineffective, even in a disaster.
only if they put the sencor very well connected to the battery will a temperature sencor have any value , like they do with ya "PRO" battery charge stuff.
even then, cooling the outside of the battery will cool the sencor, and the inside can still potentially bake , while the temperature sencor doesnt see a problem.
only if they put the Temp sencor IN the battery, could you cool everything and still read the heat deep in the battery itself.
