Can The Fenix L1D CE Run with 2AA body?
Luminous
Does anybody knows if the 2AA body of the L2D CE is compatible with the L1D?
gunga said:
Yep, same head, same light, just different body. Have fun!
From Quickbeam
"By swapping the heads back and forth between the lights I found some performance differences between the heads. Hence why the Medium setting on the 2 cell is slightly lower than the 1 cell."
I think this means they might be different?
ACtually if you read all the posts about it, it's probably sample variation.
The head unit of both lights is the same. Twas the same with the older L1T/L2T. Those ones even said L1T/L2T on the head.
THis has been confirmed about 1000 times, but since you asked, I'll confirm it here so you don't have to search the threads.
It's amazing how much info is here, but man, so many threads!
:D
david-me said:
From Quickbeam
Those are just individual differences (it's hard to find lights that are EXACTLY the same). Other than that, the L1D and L2D are the same light, except for the alutube, they are designed and produced exactly the same.
EDIT:Damn you, Gunga, you beat me to it!:rant: :)
Yep yep... same head. Got the extra lumens on my L1DCE to prove it :D
Enjoy the extra tube Luminous... I sure am :D
