Quote from tiablo website.
CREE MC-E (M rank, WC) LED
Step up and down constant current driver, with two high efficiency dual modes DC-DC regulator (PWM / PFM) and circuit to indicate the Li- ion battery from over-discharging. Working voltage is 2.7V to 18V, under the circuit flicker to remind users to replace battery.
Max output 700lumen, runtime: 45minutes( 1pcs 3000mAh 18650) and 3 hours (2pcs 3000mAh 18650)
Functions: one level output, easy to use and reliable
53 mm diameter x 50 mm deep reflector provides a greater efficient illumination over longer distances
Supports battery sizes; 2 x 3.0V CR123A batteries, 2 x 17335 Li-ion or one 18650 Li-ion battery ;two 18650 Li-ion batteries
Type-III hard anodize high quality aerospace grade T7075 aluminum construction
Switch: Tactical forward switch
Waterproof Capability: IPX-8 standard
Toughened ultra clear glass lens with AR coating
Weight: 230 g
Length: 175mm Head diameter: 57mm Housing Diameter: 25.4mm
