ColorMaker
- Joined
- Nov 3, 2007
- Messages
- 90
I have been testing 5000mah C cells and 10000 mah D cells using a cadex c7400er battery anylizer. Cells are tested individually. I set the charge and discharge settings to 1A to achive capacity. The capacity changes when charge / Discharge values change.
Charge / Dischagre set to 1A the battery capacity test at 105%
Charge / Dischagre set to 1.5A the battery capacity test at 98%
I was wondering why the capacity would change I assumed it would be the same.
JM
JM
