specter333
- Joined
- Aug 23, 2016
- Messages
- 3
Hello, I have very little electronics background and need to know if I am understanding the use of these lights correctly.
I bought these LED panels off ebay,
http://www.ebay.com/itm/262387867187?_trksid=p2060353.m2749.l2649&ssPageName=STRK:MEBIDX:IT
While researching I found more information about them on Amazon, 12v 6 watt.
https://www.amazon.com/dp/B00L11HM62/?tag=cpf0b6-20
They are made to directly replace a car's dome light without any extra limiting. However I found that they were getting extremely hot, too hot to touch. I'm not using them in a car but powering them from a 12v 1.25amp power supply.
http://www.ebay.com/itm/40086784319...49&var=670416496949&ssPageName=STRK:MEBIDX:IT
Is it normal that they would be to hot to touch? I added a 10 ohm resister and that helps the heat quite a bit but looks like I made a mistake.
If I understand correctly, at 12v and 6w they are pulling 1/2 amp each. So I can power only this pair from the power supply and would need resistors rated for more than 6 watts instead of the 1/4 watt resistors from my Arduino kit (they are getting pretty hot themselves). Is this correct?
