jblackwood
Aluminum is soft, so you're tight, it's going to flex and become damaged faster than a rolled steel slide of a Sig P226. What we're talking about is protecting the aluminum, but nothing short of a steel sleeve is going to stop a metal-to-metal deformation of the aluminum. If the fall to the concrete is less than 160lbs of force, there should be no measurable damage.] to the Cerakote.
If you check out my sales thread, I pulled a quote from the NICIndustries website that shows that Cerakote can withstand 160lbs impact, and ca flex 180 degrees with 0 paint loss. Electron Guru's hosts (as well as mine) can withstand much more punishment than traditional anodizing. And, since the Cerakote adheres to the anodized finish, yur getting triple protection. The question is, why wouldn't you use Cerakote for your EDC lights?
Here, I used a pair of metal pliers and wrenched on the head of this Blue Titanium Cerakote host. As you can see, only the peaks where damaged. No flacking or peeling occurs. Again, at 180 degrees, you could theoretically cut the light down one side and flip it inside out without the Cerakote being damaged.
HOGGER, Electron Guru as the link to his sales thread in his sig right above you. It's a one-stop shopping experience!
I get what you're saying about the hardness of Cerakote when it's on Aluminum, I'm just not sure why you decided to show a picture of it on Titanium since it's harder than Aluminum and less prone to having its anodizing flake off because of it's properties. Do you have any Aluminum Cerakoted hosts that have undergone similar treatments with pliers? (Never hurts to ask)
