I have noticed the desire for certain mods start to fizzle out, it seems as though the market is going away from certain modders work that used to be very popular. What changes hove you noticed in the modders marketplace?
The 5 minute light seems to be a new trend, too. That is a small, high output monster that is unable to run for more than 5 minutes without damage from heat.
:I think plenty off-the-shelf lights that are both inexpensive & could more than satisfy the needs of anyone
using flashlights as a tool.:
i've noticed that there aren't too many posts in the homemade lights section anymore
what modders used to be popular?
That's certainly true. That's how you can tell the market has hit its prime, when your basic off-the-shelf widget can do what most people need it to do most of the time, and so the real market growth transitions to the custom-made and designer segments. Nobody would pay $50,000 for a custom-made economy car nowadays, because they're so easy to make using robots that they can cost a quarter as much. People only spend $50,000 when they want a high-end car, or when they want to take a normal car and customize it to suit their preferences.There is a trend toward art/appearance rather than improved function from many custom makers. It's a whole new category that has developed in the past few years. Exotic metals, and coatings with elaborate machining are the focus.
Something similar is happening with the less expensive lights, too. Lots of grooving, polishing, rainbows, ninja stuff added to otherwise standard lights.
Sticking with the car analogy, the obvious comparison here is the drag-racer. Once the basic functionality of automobiles was distilled to a science, it became practical to push that technology to the absolute limit, just to see what it would be capable of if durability were no longer a concern. I wouldn't be entirely surprised, as the cost of the electronics and the emitters continued to drop, if we started seeing lights not only equipped with easily-replaceable pills, but also a design philosophy that those pills should be pushed beyond safe limits until their performance drops below a certain threshold, and then be disposed of and replaced, much like the disposable racecar engines they have nowadays.The 5 minute light seems to be a new trend, too. That is a small, high output monster that is unable to run for more than 5 minutes without damage from heat.
Ooh-Rah, so true...Crazy mods have more fun :naughty:
I would say in the lower power end this is true where it is hard for the average joe to make it work properly but once you get into the higher power stuff then IMHO the off the shelf stuff isn't as good or you end up paying too much. When you hit 1000+ lumen in LED you are better off doing it yourself.I guess that for many people an off the shelf light is simply good enough.
True, but that's not such a bad thing.The nearest many CPFers come to modding a light these days is to get a new drop-in.
Very true.Also there is nothing like making something yourself and seeing it work.
Yeah, but how many people really need a 700+ lumen light? Most people's idea of a flashlight is a plastic 2D incan or maybe a 2-4D incan Maglite. Even probably most of the enlightened on CPF are mostly satisfied with 200-500 Lumen lights that are widely available now. Prior to the SSC P7 / Cree MC-E & more recently SST-50 & 90 LED's there wasn't any way to get those light levels with anything that was commercially available at a price most people would even consider. So, if you wanted to get there DIY / modding was king. Also, prior to the LED revolution you were also largely stuck with single level lights. For example, my ROP isn't very practical as an everyday light because it's simply too bright for most uses.I would say in the lower power end this is true where it is hard for the average joe to make it work properly but once you get into the higher power stuff then IMHO the off the shelf stuff isn't as good or you end up paying too much. When you hit 1000+ lumen in LED you are better off doing it yourself.
I agree, they're fairly easy to do and have a lot of parts available for use.Mag mods are great. I love them. Heatsinks are readily available and most drivers fit in the large body. Any modifications (like switch cut down) can be done by just about anybody.
True. DIY hands on stuff just appeals to some people.Also there is nothing like making something yourself and seeing it work.
