charge with magnets and wire?
aussiebuddha
I'm looking to charge individual cells with the wire and magnet method.
anyone knows what magnets can i get that i can solder some wires to my charger? are the DX kai magnets any good for this? ta.
magnetism and heat don't mix well... trying to solder a wire to a magnet will cause it to demagnitize. :)
what i do is solder the wire to a nickel strip where a magnet to grab on to. slight problem with this setup is that the resistance between the wire-magnet-batt terminals can be a bit high.
I have some like LuxLuthor's above, which I got from Mad Maxabeam, but he isn't making them any more. They are a perfect good solution for unusual size cells, NiMH packs etc., and save you having to get a different cradle or clamp, or mod a charger to take longer cells. With modern neodymium super-powerful magnets, they make a good contact.
I recommend them, and LL has the right welder to make them properly - welded solid before the magnets have a chance of overheating.
magnetics and heat don't work well together...but that doesn't mean the cooled metal can't be magnetized again by another [more powerful] magnet
Dat de wrong link, Lux, it goes to the ROP master thread.
You mean this one.
(Poor ol' Lux - can't even find his own thread, lol)
Simple method solder an alligator clip to your wire or even a small square of tin plate, now the magnet will stick to the battery and to the wire. I use alligator clips.
Norm
just to elaborate on my earlier post...
my mistake on using the word 'demagnetize' since the act of trying to solder to a magnet won't actually remove its magnetic properties. :sssh:
yes, you can solder to a magnet but it can loose some or all of its magnetic properties the longer it remains heated and/or if it gets too hot.
the small, round rare-earth dx magnets are quite powerful and are ok for these application but their effectivity would depend on your soldering skills and technique.
I usually just clamp the wires on the magnets, or inbetween magnet and cell. However, the coating on the magnets lends itself well to welding. I welded a small nickel strip to one (at least I presume it was nickel... I ripped it off an old dead laptop cell), and had no trouble soldering a wire to the strip.
You do need a welder though...
You could just wrap the wire around the magnet a good few times and let friction and magnetic force do the rest, but it's no good for permanent connections.
