This is just an update on results posted by TakeTheActive on a modified battery/charger compatability test to see how "smart" a charger is. The chargers under test include:
Turns out the Maha (from limited testing) is proving to have one of the best scores and algorithims confirming it's high recommendation within this forum.
No surprise, here:
The Duracell Mobile Charger seems to terminate soundly, as well, and partly confirms the general consensus that it stays cools and does not overcharge. For the Maha, the worst result is with a 200mA charge current where the amount of charge put in was almost double what was taken out.
- Duracell CEF-23 Mobile Charger (completed)
- La Crosse BC-900 Charger (completed)
- Maha MH-C9000 Charger (completed)
- Rayovac PS-23B Charger (ongoing)
- Rayovac PS3 Charger (ongoing)
- Rayovac PS1 Charger (ongoing)
- Duracell CEF-20 Mini Charger (ongoing)
No surprise, here:
TTA's modified test:
(Results are further down in BLUE)
- DISCHARGE approximately 100mAh from the cell
- EASY with a MH-C9000 or BC-700 / BC-900 / BC-9009
- Otherwise, requires a RESISTOR, DMM and STOPWATCH (Instructions TBD)
.- CHARGE the cell until JUST the point of termination on Charger X
- 0.5C is recommended on an Adjustable Charge Rate Charger
- Record the Charge Rate on a Fixed Rate Charger
.- DISCHARGE approximately 100mAh from the cell
.- RE-CHARGE the cell until JUST the point of termination on Charger X
.- NOTE the Elapsed Time in minutes.
- Otherwise, check your STOPWATCH.
.- CALCULATE the Overcharge.
- MH-C9000 or BC-700 / BC-900 / BC-9009:
- (CHARGE IN / 100mAh) - 1 x 100- Fixed Rate Charger:
- (Charge Rate x (Elapsed Time / 60) / 100mAh) - 1 x 100
TTA's Charger Results
(lower % is better)
(lower % is better)
Test #1: (Complete)
Duracell CEF-23 Mobile Charger w/NEW Durabrid 2000mAh LSD #1 (1948mAh last C9000 Break-In)
- CHARGED in C9000 @ 1000mA until 'Done'
- DISCHARGED in C9000 @ 1000mA for 212mAh
- CHARGED in CEF-23 until Green LED On: 43 minutes (550mA x 43/60hr = 394mAh) 86% Overcharge ['Watermark' Primer Charge]
- DISCHARGED in C9000 @ 1000mA for 201mAh
- CHARGED in CEF-23 until Green LED On: 33 minutes (550mA x 33/60hr = 303mAh) 50% Overcharge
Test #2: (Complete)
La Crosse BC-900 Charger w/Durabrid 2000mAh LSD #1 (1948mAh last C9000 Break-In)
- TOPPED OFF in CEF-23 (Test #1)
- DISCHARGED in C9000 @ 1000mA for 200mAh
- CHARGED in BC-900 @ 1000mA until 'Full': 313mAh / 18 minutes / 57% Overcharge ['Watermark' Primer Charge]
- CHARGED in BC-900 @ 1000mA until 'Full': 289mAh / 17 minutes / 44% Overcharge
- CHARGED in BC-900 @ _700mA until 'Full': 301mAh / 25 minutes / 50% Overcharge
- CHARGED in BC-900 @ _500mA until 'Full': 306mAh / 37 minutes / 53% Overcharge
- DISCHARGED in C9000 @ 1000mA for 206mAh
- CHARGED in BC-900 @ _200mA until 'Full': 275mAh / 86 minutes / 33% Overcharge
- DISCHARGED in C9000 @ 1000mA for 204mAh
- CHARGED in BC-900 @ 1500mA until 'Full': 326mAh / 13 minutes / 60% Overcharge
- CHARGED in BC-900 @ 1800mA until 'Full': 320mAh / 10 minutes / 60% Overcharge
Test #3: (Complete)
Maha MH-C9000 Charger w/NEW Durabrid 2000mAh LSD #1 (1948mAh last C9000 Break-In)
- TOPPED OFF in BC-900 (Test #2)
- DISCHARGED in C9000 @ 1000mA for 222mAh
- CHARGED in C9000 @ 1000mA until 'Done': 268mAh / 18 minutes / 21% Overcharge
- CHARGED in C9000 @ 1000mA until 'Done': 202mAh / 14 minutes / 01% Overcharge
- CHARGED in C9000 @ 700mA until 'Done': 220mAh / 21 minutes / 10% Overcharge
- DISCHARGED in C9000 @ 1000mA for 220mAh
- CHARGED in C9000 @ 500mA until 'Done': 252mAh / 33 minutes / 15% Overcharge
- CHARGED in C9000 @ 200mA until 'Done': 375mAh / 125 minutes / 87% Overcharge
- CHARGED in BC-900 @ _200mA until 'Full': xxxmAh / yy minutes / zz% Overcharge
- DISCHARGED in C9000 @ 1000mA for 214mAh
- CHARGED in C9000 @ 1500mA until 'Done': 171mAh / 7 minutes / 20% UNDERcharge
- CHARGED in C9000 @ 1800mA until 'Done': 181mAh / 6 minutes / 10% UNDERcharge
