the 7.8V and 8.4V to the bulb there is right before insta-flash. in those ranges, you have to keep in mind that when dealing with the instaflash territory there is a lot of variation. If he were to test 100 of each bulb I'm sure there would be an "average" insta-flash point different than those represented by a single bulb.. what you need to look at is how much voltage you are actually going to get TO the bulb. generally speaking, the ROP will always be a little dimmer than a 5761 with the same power supply. You won't be driving these bulbs anywhere near the "1900+ lumen" range on any realistic flashlight setup anyways.
If you are dealing with 18650s, you can probably just direct drive a 5761 without much trouble (except the fact you'll be running the 18650s beyond their safe limit), they sag to about 3.6V fresh off the charger under the 5+A load of the 5761 anyways. after a short time they will be below 3.5V each. The problems with instaflash arise when you are dealing with larger scale li-ion cells, like Emoli or AWs "C" size Li-Ion. Those hold their voltage under those loads a lot better and need some kind of soft-start/regulation to fire up 5761s without problems.
Overall though, I think the differences between having an ROP or 5761 mod aren't enough to worry about the difference, I've mentioned this before I'll say it again, it takes large differences in output to really bother "going for it." You can hardly see the difference between 1000 and 1500 lumens. In fact we're more likely to detect differences in color temp than we are in total lumens when dealing with lights that are within 50% of each-other. In practical use, you have to ask yourself what the extra 50% output is really going to do for ya.
