jpk
I recently built a bike light using a hub dynamo, one of Martin's circuits and three leds, mostly for commuting use. The leds have separate housings so that I can aim one close to me (with somewhat floody beam) and two other ones slighty further away. I prefer a uniformish and longish beam to one or two hotspots and some side spill.
I currently have a super cap (1F, 5.5V) in parallel with one of the leds to have light available even when I am not moving. It works fine, but not for very long, no matter how long I have been riding. It stays bright only for some seconds and then it becomes the brightness of a typical 9-led 3XAAA flashlight for a rather long time.
So, I thought that perhaps I could replace the super cap with a 16380 sized LiFePo4 battery, probably from DX. The maximum current from the hub is 400mA and is probably somewhat stable at speeds above walking speed. At 400mA the Vf for the LED (U-bin P4) should be lower than 3.6, so it shouldn't be overcharging the battery no matter how long I ride.
Would that be unsafe/unwise to do? I've understood that LiFePo4 should be safe in most uses, but would this fall outside the "most uses"?
