I'll try to make a long story as short as possible. I had a UPS on my computer that one day just shut off and wouldn't turn on. I contacted the manufacturer only to find out that it was a few months past its warranty. They said that the symptoms sounded like dead batteries.
I suspected the UPS went bad and quit charging the batteries, so I didn't want to buy new batteries and find out it was the UPS all along. It uses two BP8-12 SLA (12v 8Ah) batteries. I removed the batteries and my multimeter was showing them at 8v. I have a portable air compressor that uses a smaller 12v SLA battery, so I opened it up and connected a BP8-12 battery to it and let it charger overnight. I checked its voltage and it was holding at 13v, so I put the 2nd battery on and charged it overnight. Then I let them sit for a couple of days and checked them, and they were both holding their charge.
I put them back in the UPS, plugged it in and it came on. I simulated a power failure by unplugging it from the wall and it shut off. It didn't even attempt to run from the batteries. I connected my multimeter to the UPS to test the current and found that with it plugged in it was drawing a small current from the batteries rather than charging them.
So now I'm stuck with a dead UPS and two good batteries. It's not economical to try and sell them because shipping would cost too much, so I though I'd try to make up some lights out of them to light up the house when the power goes out. They're the same batteries used in some of those emergency lights you see mounted on the walls of a lot of buildings.
My only obstacle is how will I charge the batteries. I didn't know if they needed any special charger, which is why I used my air compressor to charge them, but I can't keep taking apart the portable air compressor to charge them. I searched for 12v SLA chargers and the only ones I could find were designed for car, motorcycle and marine batteries, and they costs over $100.
I have a couple of portable jump starter/air compressors that use a larger 12v SLA battery. One of them died, and I still have the wall plug that was used to charge it. It puts out 12v @ 500 mAh. Can I just cut the wires and hook it to the + and - terminals of the batteries to charge it, or does it require a special charger with electronics to monitor the charging?
