I have a bunch of cheap outdoor ebay solar rechargeable LED lights with li-ion 18650 3.7v batteries.
If I replaced the 3.7v li-ion batteries with 3.2v LiFePO4 18650ifr batteries, would it work just the same? Would the solar panels and circuitry that are designed to charge 3.7v batteries overcharge the 3.2v Lifepo4 batteries (I assume yes, but the lifepo4 batteries are more stable of overcharge, right)? Will the lights be the same brightness with the .5v lower voltage?
Also the li-ion batteries are 2000mah, the LiFePO4 batteries are 1500mah. I think that means the solar lights won't stay lit as long of time through the night?
Last thing, can I use the lifepo4 18650ifr 3.2v batteries in my 18650 li-ion 3.7v flashlights if I use a lifepo4 specific battery charger? -what will the result be --short charge life, dimmer light?
Thanks for any replies.
