I started biking to work recently, which means it is a bit dark for my ride home (short days in the NW of the USA). A friend pointed me to a 4Sevens quark and I have been using this strapped to my bike helmet. It has been a great light, but I want more light in front of me.
I just received my DX order consisting of 4 flashlights running Cree R2s (and the 18650 batts and charger). These will be handlebar mounted for the most part. I anticipate having plenty of light out front of the bike, but I would really like to add some broad flood light in the ~10 feet in front of the bike. I'm hoping there may be some cheap (free) hacks I can try out to convert one of these cheap DX lights to be pure flood.
It seems to me that my two options are (1) scatter the light at the emitter so my whole spill area receives more light or (2) scatter the light at the lens.
After a few searches I believe the led has a glass dome, which seems more difficult to sand down. It also seems to me that even if I approach a broad bulb style of illumination, there is still going to be a large part of the light caught by the reflector. So my guess is that this will not be a good option.
The lens it comes with is glass. I assume I can just scuff this up with some sandpaper or other abrasive, and get a diffuse flood out the front. It may cost a significant amount of light, I really have no idea. I guess if I hate it, I would just be out one lens
Actually just had another thought while looking at it. When I unscrew the lens and play with it, I see I only barely have to push the LED past the edge of the housing to get a good connection. So it looks like it would be simple to cut off the front ~2/3 of the reflector, and cut off the back ~2/3 of the head. This would put the lens just barely in front of the LED and should be almost pure flood. I guess I would have to cut the reflector down in stages to experiment with the side of the spot.
The current spill area is actually about ideal, I don't suppose there is any simple way to make all the light focus on the current spill area?
