scott.cr
After getting some hints from this thread, I decided it was time to get my butt in gear and cut the foam in a new Platt tool case I had lying around the house.
With about $1,000 in lights sitting around on my desk at any given time, and ready to be knocked to the floor, I figured a way to neatly stash and file my non-daily-use lights would be awesome.
After spending some hours Googling "hot wire foam cutter" and weighing the options between build and buy, I decided to buy. Yeah, I know, a DIY job can be so much better, but I decided to take the fast & easy way out and bought a scroll table set from hotwirefoamfactory.com. This unit works okay but could really benefit from a variable power supply... this will probably be my next spare-time electronics project.
In the original thread, the poster who cut his own foam cases said he makes foam cutting templates by tracing the equipment on posterboard and cutting it out. Well that's not obscenely perfect enough for me, even for use on an imprecise surface such as flexible open-cell foam, so I drew up my gear in AutoCAD and cut out the drawings on a plotter to have perfect templates. Additionally, in CAD you can proportionately shrink the drawings and the resulting template will create a tight fit between foam and flashlight.
This was my first time laying out a foam case with more than about two items so my use of space might not be considered optimal... would love to hear any suggestions for improvement. I learned a TON during this little process though... cutting foam could be a science in and of itself! My Platt case came with pre-cut "pick and pluck" foam, which is not ideal for custom cuts, because you end up with weak spots where the pre-cut foam will want to separate. (If anyone knows where to buy solid slabs of open-cell foam please add to this thread.)
I would like to offer my foam-cutting expertise to other CPFers who might want custom cases... PM me.
Now for the pics...
Now for the pics...
