hi Al,
Adding a transistor to the normal FMMT614 output seems possible, but would also give up the ability to run over the normal voltage range of a nicad cell (right?). Seems like you'd need 1.3v to get two BJT's turned on, and perhaps more if the FMMT614 is driving a logic level N mosfet.
.... or is there an app note that I missed? ....
I'm presently using the Zetex boost converter to drive 4 yellow 5mm LEDs in series. I'd love to use it to drive one of the 4 dies in the upcoming Cree MR-E. That would simplify the packing to be able to eliminate the 5mm LEDs from the design. I'm sure the Zetex converter could push current through the MR-E die, but I'd like to get a higher current level.
I'd also like to use a supercap instead of the nicad cell, hence the desire to find a converter that uses all of the energy in the supercap. Unfortunately, the capacity of a nicad is much larger than that of a similarly sized supercap, so I'll be sticking with the nicad. I've had very good luck with the nicad in my current designs, so can't complain. Still, it would be nice to not have to ponder the condition of the nicad.
hey Al, any comments on the intended application for the zxsc310? Strictly for single-cell LED flashlights, or was there something else in mind? A power supply for little mp3 players, maybe?
regards,
Steve K.
Hi Steve,
I dont think you missed any app notes
but to turn on a bipolar you need about 0.7v
and that's about it because some modern bipolars can saturate down to 30mv or so,
so all you need is the right configuration of a PNP and an NPN and that might do it.
I say 'might' because theoretically it should work, but i've never tried it at so low
a voltage before. Speed is also an issue, so the only thing i can say is if you wanted
to try this as an experiment maybe i can come up with a circuit. Of course this is also
dependent on finding a transistor that can saturate to a low voltage at a high enough
current, which means i would probably look at the Zetex line again.
One thing you might want to keep in mind is that the only thing that prevents a driver
from working at low voltage is the drive voltage available, which doesnt have to be
able to deliver the full output current but only the driver current. This means if
circuit complexity is not an issue (sometimes it is though) a tiny low current boost
circuit could be used just to develop the drive voltage, then go from there. Of course
that's the worst case situation.
From what i see about the 310 chip is it does already work down to 0.8 volts, so
that's not bad i guess. With some current boost on the output maybe it would be
possible to get a lot more drive current. i cant say how the efficiency would be though.
Note that the configuration might have to change a bit to accommodate two transistors
instead of one. Might be a little bit of a trick too so the output doesnt get inverted.
Maybe three transistors? Maybe a high speed inverter?
Are you into experimenting with these kinds of ideas for higher output current?
The 310 was originally designed to work in LED backlighting applications, so it was
bound for LED driving from the start. I dont think this prevents one from using it
in another app that needs voltage boosting however.
