Clickies....errrr.....
Status
Not open for further replies.
darklord
UK
I must admit I'm lost with this term clickies :sssh:
I mean I know it means what we in the UK call a switch...but what is a 'forward' clickie?.....and how does that differ from a 'reverse' clickie?
Sorry for the daft question, but it's proving a language barrier!
I Suggest Taking A Look At The Welcome Mat
Q: How do I choose a switch?
A: The "reverse clickie" is very commonly available in inexpensive and general use household and outdoor flashlights. It has a button which must be fully pressed until it clicks and then fully released in order to get light. Once the light is on, a soft press will momentarily turn the light off, and once the button is released, the light will reactivate. This is a very inexpensive (and hence popular) switch type, but it is not suited for signaling or momentary operation.
A "forward clickie," however, can be gently pressed from the Off position to momentarily activate the light, and it will turn off once the button is released. The user can also push the button until it clicks to keep the light on. This is available in some Maglite, Streamlight, Inova, and Surefire models.
You may also sometimes hear the term "Side clicky" as well. And that just means the on/off switch is on the top of the light as is the case with m@glites.
The mechanism that allows momentary contact in a forward clicky switch before being locked ON requires a more complex construction and an additional spring, IIRC.
Status
