Looks amazingly clean! What a slick little light that's going to be. :twothumbs
I so wish I could post pics of the new Dynamo version & other model's but I am bound by 'disclosure' contracts for now on all new models in the range...
what if I give you some of this yummy popcorn?
Where did you het the remote leads from? Have you made these yourself, and are they available to buy on there own??
I was ordering some stuff off Mark at Cutter this arvo
and he was saying these had just arrived.
He was very impressed with the quality and "smooth as butter" threads.
Top stuff Ktronik.
Cheers
Dpm
Very nice looking setup. How does this light compare to the other Cutter kit, the one made by Night Lightning?
This is a nice looking setup except I do not like the clamp. I would prefer a clamp that does not require me to remove everything from one side of my handlebars to mount or dismount.
Also, I have about 3 different bar diameters that I would want to use the same light on. Any thoughts of a quick detach mechanism and selling extra bar mounts of differing diameters?
Is the light going to be trail worthy?
They make some great stuff, & have a few different kits, but for the triple would be same light output with cree R2 but max is 700ma, (k-light) some of there units have a 1200ma max & a tighter beam, so it depends on what you are looking for...
K-light is however smaller & uses smaller LEDs & optics, thus the difference...
K
To clarify:
The K-light max is 700ma?
The Mini-Blaast can run at 1000ma I see. What would be the light output comparison- MB R2sat 1000ma, K-light XPE?
K-light is smaller than Mini-Blaast?
No Probs:
The K-light Max is 1000mA (tested), the XPE LED on paper is 700mA max, but some people will run them @ 1000mA...for testing I have been running mine @ 1000mA. it won't kill it, but it may reduce the overall '50,000 hrs before lumen degradation' factor... but really only if you run it with the thermal protection OFF & on FULL in still air. normaly, even if on 1000mA & the light gets too hot, the thermal protection will kick in cooling the light...
The Mini-Blaast is a 35mm optic, the K-light is a 20mm optic, both use cree R2 LEDs pretty much the same LEDs, but the 35mm optic goes down to 10 deg & the 20mm optic 16.4 deg, So yes K-light is smaller
So, given the same power & the same LED, given proper cooling, the light output would be basically the same, but that would be before the optic, after the optic may be different with different optics.
hope that helps
K
