CNC XPE bike light
ktronik
Australia
CNC XPE/G bike light
A few shots of our CNC XPE bike light.
Specs:
630lm out the front
R2 XPE LEDs driven by a blfex driver.
so here is a mock up of how it all goes together, it should be super quick to build, & can be fully pulled apart to swap / upgrade parts if needed. not shown is the bar clamp, its still being made...
Driver goes in (sits on top of a o-ring)
Driver holder goes in
Rear cap, pushes on the driver holder. Rear cap will have a cable gland coming out of it & the bflex onboard warning LED will glow through this.
Rear cover screw on, sealed by 1 o-ring & waterproof grease on sides of rear cap.
LED pcb drop in
Optic, o-ring, glass or lexan lens, o-ring & front bezel
feeler removed
Testing is going well, thought I would tell you guys of some ideas I have been playing with...
Flight deck Remote switch for light:
The flightdeck wire kit has 4 micro wires on the premade switch... not really solderable & too small to be strong...
good news I have found a switch that will fit really well into the removable blank cover plate (that sits where the flightdeck remote goes) that is all ready on my lever, so on my bike, I will have a nice tactile switch on the STI road lever, on the same string, I will add another on the tops of the bar, just before it plugs into the light...so remote on the tops & @ the lever, both a have a great 'snap' action we need...
K
OT:
how does the brightness of the cold white compares to the one of the warm white MC-Es?
Do the warm make a nicer light?
OT:
Hey Yellow, have a look @ the tints on this post, I have mixed 3 different tints to get a better overall colour retention & I must say I do really like it...but you would get less lumen out the front...
EX of MC-E tint/Lm:
Multichip Bin : MCE4WT-A2-0000-000M01 Cool white, 430 min lumens, WH Tint
Multichip Bin : MCE4WT-A2-5C0-K0-0-00001 370 min Lumens Neutral White
Multichip Bin : MCE4WT-A2-6C0-J0-0-00001 Warm white, 320 min lumens, E6
Difference in brightness is 110lm for the warmest & coolest, thats the output of a nightrider minewt just there...everyone is different, some have to have the raw output, but for the OZ bush, lots of browns ect, I do prefer the warmer tints...but on the black road it may not matter much...
I think the key is to have a mix of tints, thus not to loose to much of your raw output, & for my ~1000lm dynamo light a 100lm here or there was no issue...
On the newer XPE triple light, cutter is looking in to getting some custom boards going with one LED that has a warmer tint, for future runs...
Best of both worlds for the bush...here in OZ anyway...
K
Sorry for the delay guys, got to get the cutter order out first, you guys are next so 2-3 weeks...
will be worth the wait, we have gone over-board to make it fully dunk proof, glad I did as I went for a swim in a river last night, err on my bike... :o
Working on a new dynamo circuit as well, more on that soon, my plan is to have battery & dynamo circuit fully dunk proof as well, so if I choose to go for another swim on a cold & rainy night, I won't short my electronics / battery...thus making it home to tell the tail...
you guy in NZ will get most use of this 'over-building', lots of rivers to cross on the AV MTB ride...
Best
Ktronik
Here's a quick pic...this K-light kit is exclusive to Cutter electronics, this was the first run to be done...
K
Its ironic that the clamp looks so huge compared to the light itself (which looks great!).
What is the news on the dyno circuit? Were you planning on just putting your basic tuned rectifier circuit in there? For 3 led's, a boost cap, bridge rectifier and smoothing cap is all you need down to something like 5kph, right?
Yes clamp is 31.8mm dia (ID) so does look larger than the older size...but light is small as well...
I have a new proto dyno version...sorry no pic for now but its along the lines of 'black betty' above, but custom made for the dyno...
more details as they come to hand.
K
Kit build order:
Solder wires to LEDs, make sure to also solder the series link.
Note the 3 holes for the optic posts to sit
The optic post clear the MCPCB & need to sit in the post holes of the housing or the front bezel will not do up correctly.
Adding thermal paste, push the LED MCPCB into place, you don't need heaps of paste, just enough for a thin layer & not enough for it to slop around in the housing & get on the optic
Add the optic, making sure that it is correctly seated into the optic post holes on the housing, this is very important as if it is not seated correctly, the front bezel will not do up fully
Add non-lubed o-ring
Add Lexan Lens
Add lightly lubed o-ring on top of lens, & push the thin lubed o-ring around the outside of the thread, lube bezel thread with thermal paste / grease & screw on, make sure that as you do so the final inside o-ring stays in place
You are now ready to move on to the rear section, might pay to test your connections are correct with your meter & the front bezel is correctly fastened
Build order of rear section
Solder the LED leads to the Bflex board, then insert the pre-wired Bflex driver, driver holder & o-ring into the housing, making sure the lubed o-ring sits in the slot provided
Heatshrink 2 layers of 3mm shrink to the driver lead
Add Lexan donut attached to the IP68 cable gland, making sure that it sits on top of the o-ring
Then screw on rear cap using heatsink paste / grease on thread & thin outer o-ring, as was done on the front
Trim the 2 remote wires to length
Heatshrink the other length of 3mm to the power lead
Before wiring plug, push over the 5mm heatshrink
Trim plug
Wire plug, it does not matter which way around either remote plugs are as they are not polarized
Twist plug & slip 5mm shrink over wires
Heatshrink 5mm
Heatshrink 8mm, long enough for the glue to come out of the ends, as this is 8mm dual wall glued 4:1 shrink
Heat shrink to bend
Wire Battery lead, remote lead & your ready to rock
K
Ktronik
This is a fantastic build! You've put together a really well thought out package! Nice work.
Wow.
You've done your homework.
Optics easily swappable, I like that.
:hitit:
Thank you, :) everything is swappable & future proof.
I must say the engineer has done a bang up job on the QC of the housing...everything butts up perfectly & threads are slickly smooth, so I am very happy all around :thumbsup:
K
Thanks mate!! with all you guys making the super bright lights, I though I would stick to the medium bright LED bike lights...
With 2 on the bar, one wide & one narrow, then one on the helmet, it should be more than enough light for now...
K
