Darell
Jeez. I was watching the "interest" thread and not this one. Now I'm on the proper page! So great to see this coming together after all your work! And I LOVE the STI switch plan, of course!
Thanks, answers it all very well. 20mm- a seriously tiny powerhouse. This would be great for helmet-mounted lights.
How many lumens are you getting at 1000ma?, with good cooling airflow?
email question
LED in switch sounds interesting - would this be integrated into the switch unit or is there a special glowing switch we can get?
Yes built into the current switch unit, but if you wanted to use a plug on the remote, you would need a 3 pin plug rather than the 2 pin supplied...
Great looking light. Another switch question for you: Is there any way to have a switch that is attached to the light body? For me, that is a better option than a remote switch.
Thanks.
Just putting an order through with Cutter for the kit - but not terribly sure on which optic is the best? Will probably get two, the Frosted Medium and Narrow Lens Front. Will be handlebar mounted and used as the main source of light for MTB.
Just tossing up whether to bother with the Narrow as well as the medium?
Any thoughts?
Got 90% through putting it together tonight - couple of things I noticed:
Make sure to use very small wires for the LED wiring - I tried using slightly larger guage wiring, and it was quite difficult to assemble. I broke one of my solders once trying to squish it in. Not a fault of the design, jsut need to be aware of using smaller wiring.
I had my bflex pre-wired and noticed that in the drawings its shown that the yellow and white wires are used for switching whereas in my case it was yellow and green were wired for switching. This threw me off a little as I didn't want to pull it all apart to check which wire was which once I had it all assembled.
Also, make sure there are no burrs on the lexan lenses, or the LED PCB as the machining is to such a high tolerance that it will have an impact on the fitting. It's much easier to file off these burrs before you do the soldering or remove the protective plastic from the lexan lenses.
Must say I'm very impressed with the smoothness of the 22 degree frosted lens. Its very very nice.
Looking forward to test riding.
Will finish off on the weekend. Have a 7.30am meeting tomorrow at work and need my beauty sleep haha.
HI,
Please use the wires supplied in the kit, as they are the correct size gauge.
Colour of the 2 switch input wire does not matter, as the 2 switch input wires are not polarised.
Yes lexan / bflex may need to be trimmed as housing has very tight tolerances. I have only needed to do the bflex so far.
Narrow frosted is my fav...totaly smooth beam!!
Have fun riding, & please post pics of it on your bike
K
I didn't get any wires for wiring from the bflex to the LED or else I would have used them. Not a big deal in the end though.
I understand the switch wires were not polarised, but in the loom there is also a spare pair of wires that aren't connected to the board. I assumed these are included for if you want to remotely mount the driver 'stat' LED outside the housing. Just need to take note which wires are connected to the driver and which are 'spares' before closing the housing up. As in my case the wiring colours did not match the instructions. Again, not a big deal in the end.
Haven't had a chance to test run it on my bike yet. Been too busy. :scowl:
I assembled and used the K-Light I ordered off you a while ago, I would like to let you know a major design flaw.
The inner body assembly has a hole drilled through into the inside, to mount the handlebar assembly.
This is disastrous as, it makes the a great light, unable to keep the water out... The first trip out in the rain and the internal body section of my light, filled with moisture and destroyed the circuit boards inside. Even though it had the screw in place to prevent this!
Is there any chance of getting a body that does not have a huge hole right through it!? I have been very disappointed, with what has happened. I now have a broken light...
I'm trying to figure out how water has destroyed the circuit. I've used this circuit in many hundreds of devices, and after I solder to them, I clean them with... water. They are completely saturated. They don't work reliably when wet. But once dry, they're of course perfect. If water was the problem, then dryness is the fix.
Ktronic,
Re - using Cutters current kit with a dynamo.
How much room is there at the back of the housing where the bflex is?
Could I just get 4 diodes in there or would there be room for a worthwhile smoothing capacitor too ?
Cheers,
Leo
Or should I be waiting for your OEM version !
