ernsanada
- Joined
- Apr 29, 2004
- Messages
- 2,962
I just received the Coleman CREE CR123A Lithium Pack-Away Lantern for a review. After I finish the reviews the lantern goes back to The Gear Revival
You can purchase the Coleman CREE CR123A Lithium Pack-Away Lantern at The Gear Revival.
Use code CPF10 at checkout for 10% off your order, including anything else from the site.
Order over $100 worth of items and get free UPS Ground shipping in the US (no code needed, despite what the homepage says).
Get a free Nalgene bottle on orders over $85 (no code needed, we just throw them in orders until we run out).
There is a thread on the Coleman Lights at CPFMP
Costs $59.00 before discount.
The Coleman CREE CR123A Lithium Pack-Away Lantern is a very nice lantern.
The fit and finish I give the grade A.
I like the feature of how the lantern stows away. A very good idea if you are camping, small and compact and it doesn't take up much space. Also it keep the clear plastic lens from getting scratched.
Uses a Cree XRE.
Operates 5 hours on high and 12 hours on low.
Comes with a carabiner. There is a loop by the battery access cover that you can hang the lantern upside down with the carabiner.
Multiple settings. High, low and emergency strobe.
Comes with a Carbiner and instructions.
Comes with 3 Duracell CR123 Batteries.
This is the mutiple setting switch located on the top. High, low and emergency strobe.
This is the bottom. Turn the bottom round cover counter-clockwise to remove.
To install the battery cover line up the slot on the bottom of the battery carrier section to the the raised part located towards the bottom of the cover. Turn the round cover clockwise.
High setting
Low setting
Uses a Cree XRE.
High setting
Low setting
