thefish
I need a new lantern for camping and emergency lighting. If money is no object which lantern is better? The Coleman Twin LED or the Rayovac Sportman Extreme LED? Which is brighter? How do they compare is size?
Yes, it is sort of a stock answer, but the truth is, "it depends".
Brightness:
The Coleman Twin claims 390 lumens, while the Rayovac claims 300. I doubt either one is being rated in the out-the-front lumens, but I still believe the Coleman is brighter.
Weight:
I've handled the Rayovac, but not the Coleman Twin. However, the Rayovac takes three "D" cells while the Coleman takes eight. I think it is pretty clear which one is heavier.
Build Quality:
The Rayovac feels very, very nice to handle. The top and bottom snap together cleanly (after a few minutes figuring out how the battery comparment closes). The Rayovac feels like a tool. As mentioned above, though I have not handled the Coleman Twin, I went to Sears last week and handled some of Coleman's other lanterns, and with respect to build quality, I was *not* impressed. It felt very "plasticky," like it would break if dropped. I am not saying the Rayovac would not break if *it* were dropped; however, the overall physical impression I received from handling two Coleman lanterns was not one of robustness.
That being said, adirondackdestroyer owns one and reviewed one on YouTube. Perhaps he will chime in here with respect to build quality.
Runtime:
I am not sure if either one is regulated or if they are both direct drive. The Coleman affords you the opportunity of selecting from a wide range of levels, which means in all likelihood it will run at a much lower level for much longer.
Beam Quality:
Both lanterns have diffusers. The Rayovac produces a nice clean beam, and the photos I have seen of the Coleman Twin indicate it, too, produces an artifact-free or close to artifact-free beam. The Rayovac's lid can be removed and the hemispherical diffuser exposed, allowing even more light out.
Size:
Again, based on photos and the other Coleman lanterns I handled last week, the Rayovac is quite clearly much smaller.
So, to answer your original question, "I need a new lantern for camping and emergency lighting. If money is no object which lantern is better?", I would have to say "it depends." Going back to the categories I outlined above:
Brightness:
The Coleman is brighter. If you need absolute maximum brightness, this is the one.
Weight:
The Coleman is heavier. If weight is a concern, the Rayovac is lighter.
Build Quality:
Bearing in mind I have *not* handled the Coleman Twin but have handled other recent Coleman lanterns, I would have to say the Rayovac has a much nicer "feel" to it. It just gives me the impression of being better built. If you care about the apparent construction, the Rayovac, IMHO, just feels better made.
Runtime:
This depends! The Coleman has a much wider range of levels to choose from, which may mean it will last longer at the level that is right for a given application. So, for runtime, the Coleman may be better.
Beam Quality:
Judging from beamshots, I would say they both have very nice beam quality. The Favourlight clones (Rayovac, Gentos, etc.) have a very nice diffuser. I would probably give the edge to the Favourlight clones.
Size:
Rayovac is smaller.
Cost to Run:
Initially, both lights are similarly priced. However, the Rayovac takes three "D" cells and the Coleman eight. If, as you indicate, "money is no object," then this is not a factor for you. However, it is clearly cheaper to use three alkalines or NiMh than eight. I am trying to figure out if a 12v SLA battery can be modded to fit in the cavity of the Coleman Twin. If it can, this may make the Coleman an excellent option without the inconvenience of eight individual cells.
My personal opinion? For build quality, beam quality, size, and cost to run, I tip my hat to the Favourlight clones. For overall brightness and variable intensity, along with the advantages drawing less current entails (longer runtimes at lower brightness) I would choose the Coleman.
I hope this helps!
LEDAdd1ct
