That is an aspheric beam profile and you won't get that with a collimated beam (in my limited experience).
The collimated light I have has a very narrow (5.5degree) optic and seems to "push" the beam out, and does not have the tight hot spot, but more a swath of intensly bright light that is more diffuse but has very little spill outside that main swath it pushes out. It provides more useable light over a broader area, but does not throw nearly as far as a dedicated aspheric thrower.
How far out do you want to reach out & how big a light are you willing to tote?
You may want to take a look at the Ray D1:
http://www.candlepowerforums.com/vb/showthread.php?t=256948
Close to 20,000 lux from a RCR123 in a pocket light sounds interesting.
Check out Selfbuilt's review & do a search in the Marketplace for the sales thead.
The Elektrolumens DeCree is another pocket rocket that takes an 18650, is single mode, direct drive & puts out around 300 lumens OTF (measured).
It is pretty pocketable also.
http://www.cpfmarketplace.com/mp/showthread.php?t=202522
Or, you just could get a DEFT...
http://www.candlepowerforums.com/vb/showthread.php?t=211519
You'll love the beam shots in this thread.
The Dereelight line also has an optional aspheric head that can be lego'd onto thier lights that may be worth checking out. You get to have you cake & eat it that way.
Somebody else will have to chime in on the bigger ashperics, I don't have any experience with them but like the beam pattern also.
