superflytnt
- Joined
- Aug 19, 2008
- Messages
- 360
What's up folks.................I've been catching a bit of grief about this and was just curious if anyone else uses this method. In the LED forum I was comparing the brightness between the Streamlight Microstream and Fenix LOD (on medium) by pointing them both at the ceiling (about 6 inches from it) and blinking them back and forth while looking at the floor to see overall reflected light. I was slammed by a couple of members who said that the MS has a bit tighter spot and that it skews the results in it's favor. At 6 inches? These lights both have a hotspot...............am I wrong that these are similar enough beam profiles to compare using this method? Does anyone else out there use the ceiling bounce method to compare overall output? I thought it was kind of a poor mans standard but if you'd if you believe them it's all but useless......................
