Not a big review but for those who are thinking of buying either a Peak AAA 3 led light or getting LED_ASAP to mod your AAA light.
I got a TX1J luxeon using his "new drilling technique" and "max brightness".
For the first 2 shots, I had all 3 lights in it.
Each light is placed 16cm away from the cabinet.
From LEFT to RIGHT are the Peak, Arc, LEDASAP Arc.
This first pic is of all 3 lights with the flash on.
This second pic is now w/o flash.
I just took a tape measure and checked the diameter of the beams. I came up with:
PEAK 15 cm, Arc 26 cm, LED ASAP 45cm
Next up I took a CD jewel case and took a shot
of it lit up by the light from a distance of 30cm.
Peak
Arc
LED ASAP
As you can see, if you want a nice flood, LED_ASAP is the guy you want to speak to. If you are looking for a nice tight beam then it doesn't hurt to go with the Peak. The only suggestion I have is to get a Peak with a "prototype" body. That way you get an Arc AAA body instead of the extra long Peak body which I can't stand. I personally prefer my mod over the Peak. I like having a nice big flood.
These pics were taken with a Canon S230 in manual mode. AiAF and the AF beam were left on. ISO 100. I left white balance on auto.
Peak
Arc
LED ASAP
