Mr.Sandman,
The easiest way that i found to get the Diode out of the shaft was to start by removing the laser module from the casing and then de-solder the 3 pins from the diode that are attatched to the circuit board(make not of which pin goes where) Then, desolder the APC wires (Black&Red).
Now with a flathead screwdriver, unscrew the diode backing cap! There are 2 lens thingy's in front of the diode which you will have to take note of which way they go in also because they may accidently fall out after you have taken the diode out.
Now why do you want to take the diode out? If it is to replace the diode then you will have to replace it with a 500mw 808nm diode. And i have heard that some people are having problems realigning the diode up with the lens or whatever it is after re-soldering the diode back into place!
I have done the above procedure and i must say to be very cautious and slow with everything!
Although i am yet to replace the dam diode yet so if you get to that part of the procedure and have successfult gotten the laser to work afterwards, then let us all know Mate
It's a bit blurry but this is a basic outlay of the components
Oh i think the best way to do the 1st stage mod is to cut the apc wires , it is apparently the same as POT mod but you don't have to stuff around as much.
We need people to help with another mod for these NewWish lasers, Hell theyve got a 500mw diode in them so i want to get a little more from them than just 10mw
