Considering making a flashlight from scratch
Mattmanic
Hey, I'm just starting my D&T A2 coursework (second year of college after high school in the UK) and I have until friday to think of what I'm going to make for the rest of the year. I'd quite like to make a flashlight, although the problem is that I need to involve a wide range of production techniques in my manufacture. Most of the custom torches I see around here would just need a couple of hours on a lathe, tops, and a bit of drilling.
I'm after ideas or inspiration for a body that would take me 60+ hours to make, if it's possible to fill that much time atleast.
As for what to go inside, I've got a 55w hid kit on the way and some 12v sla batteries, or I could do something with LEDs perhaps.
Any suggestions for other things I could make are welcome too :)
Thanks
Matt
One idea I've had is to make a big HID flood light and have it as an emergency light station and then I could have 2 or 3 smaller lights that dock in it and charge off it, so incase of a power cut, the flood could be turned on and the more portable 1D mag(ish) sized lights could be pulled out and used.
Hi Matt, have you had any more ideas yet?
How about manufacturing a parabolic reflector for the HID parts you have on order? Have a look at Lightswards inspiring threads here on CPF, I know it would take me more than 60 hours just to create the mould!! :)
Didn't think about building the reflector too, I have acsess to equipment for aluminium forging, so I could make the mould, forge it then polish it for a few days...
I talked to my teacher today about my idea today and he didn't think there'd be enough to do to get all the marks I want. I'll throw some designs together on Google Sketchup and see what it looks like.
If I can't decide by then end of the week I'll just make a hi-fi cabinet :L
Before you could even start machining anything you would be at the drawing board for more than 2 hours.
Yes If you had a print in front of you with some nice equipment you could whip out a light in 6 hours. As for a Custom Torch in 2 hours............no way :)
You sound like all my friends.........It usually starts with "hey you can make me a knob to fit my new quick detachable gunsite in 10 minutes" 3 hours later a knob is born.
If you have never done something before or in fact do it everyday you can add at leat 10x the time you "think" it will take :)
Mac
Tell me about it... :P I know everything takes longer than expected. A few weeks ago I set about making a 22mm long feed tube for an airsoft gun, ended up taking me about 1 1/2 hours in the end. Should've been no more than 20 mins.
Last year I designed and built a PC case, I probably spent atleast 15 hours solidly drawing and tweaking the CAD designs before I started building. That was after doing a design specification and analising and chosing from about 20 sketches I'd done.
We have 1 term to design and do the written work and 1 and a half terms to make it.
I think I shall go for the hi-fi cabinet/desk after all and if I have time make a torch or too to go in it.
Best of luck with your D&T course Mattmanic, and remember that as soon as you start machining things, "five minutes" becomes a very long time :devil:
I have a month off from uni at the moment, and I'm considering building my own brass P60 host using drop-ins from DX (for now) has anyone got any hints on such an undertaking? I've had a fair amount of machining experience, I built a model steam engine last year for my first year engineering project, and I thought I'd like to combine two of my favourite pastimes: Lights and Metalwork.
