Oink
- Joined
- Mar 9, 2008
- Messages
- 45
Apologies if this has been posted before. I am not quite sure what to search for and apologies for possible usage of wrong terms.
I have an unreliable 20 mode MTE C3 (Rebel, single AA). It suffers from flickering and half of the time, it wouldn't come on. The flickering stops if I short the circuit by connect the negative end of the battery directly to the body, bypassing the switch which seems to handle all the modes etc. All the contacts are clean and the culprit is either the switch mechanism or the mode-switch. It has a thin wavy copper washer thing next to the spring which puzzles me somewhat.
To make it usage as a flashlight instead of occupying room in my drawer, I wonder if there is a quick way I can just bypass the modes and have a simple switch that turns it on (100% output) and off. I want to sacrifice all the modes in hope of better reliability.
Thanks in advance.
Added:
Is what I want to achieve "direct-driving"? Some people have noted that this flashlight is not compatible with 14500 batteries, if I bypass the mode-driver, the Rebel LED is supposed to be able to handle 3.7v 14500, no?
Thanks in advance.
Added:
