Converting a Halogen canister light to LED
Chii
Hello everyone :thumbsup: ,
A newbie Swedish diver hope to get some nice ideas and tips to convert my divelight to a LED light.
This is the raw material i start from, a canister light from the early 90s:ironic:
http://www.dykarna.nu/photoAlbum/showPhoto.asp?albumId=15836&photoId=175055
I know very little about electrical appliences, i mostly end up breaking stuff rather than fixing them.
My ambition is to use these parts to convert the light.
This housing http://www.dealextreme.com/details.dx/sku.13803
And this LED http://www.dealextreme.com/details.dx/sku.11809
So far so good but there are a few issues left before assembling,
How do i mout the LED on the reflector?
Vill the led be heat isolated enough to work? The housing on the lamp is made of steel and my idea is to connetc the reflectot to the housing by heat paste,
And the biggest question i need to reduce the volt from 12V to 3,7V where can i find a transmitter compact enough for this job?
Hope to get some valuable advice from professionals to complete my kick *** divelamp :twothumbs
Best Regards /Daniel
Suggestion...
Why don't you get this one?
http://www.dealextreme.com/productimages/sku_14645_4.jpg,
http://www.dealextreme.com/details.dx/sku.14645
Get the reflector+driver+heatsink... you will spend a little more, and you will save a lot of time.
But keep in mind that the reflector+drop in module is not enough to heatsink a P7, so you are going to need to machine a piece to make the "path" from the brass to the main body, and of course that is in case it is made from a metallic material.
Another opction would be to get that light, change the o-rings, use tons of PU, and a polycarbonate lens to make it waterproof. Then you remove the tailcap, cut the body, and fill it with PU or Epoxy after soldering the wires from the canister.
And if you don't mind to, I suggest you to change that NiCd pack for a Li-ION pack...
Javier
