PCC
Let's just say that you will lose the ringy artifact filled beam and replace it with a nice round hotspot if you get the 1 Watt drop-in (not the cheaper one with the 10mm LED). In terms of brightness it's roughly twice as bright in the spill but slightly dimmer in the hotspot but the hotspot covers roughly twice the area. This is definitely not a thrower. You absolutely will gain in run time, probably on the order of two to four times. Conceivably, if you put a Nite Ize drop-in into the tail cap and run the stock bulb until the batteries die, you can then swap in the LED and get the same run time on dead batteries or more compared to the incan bulb on fresh batteries!Will the NiteIze give me compatible light with longer life? How significant of amount is the upgrade?
