LED-holic
This might be old news to many of you, but I just figured it out.
With the reverse clickie when you depress it half way after clicking it on, the light turns "off".
So with my L1D or L2D, when you first turn it on it goes to "low". If you half-press the clickie momentarily and release, it goes to "medium", and repeat again it goes to "high", and repeat again it goes to "S.O.S." as an example.
What I figured out is that if you half-press the clickie and hold it for more than 1.5 seconds, the light is then effectively off for 1.5 seconds and then restarts at "low".
So as an example, if you're in "medium" and the next mode is "high", but you want "low", simply depress half-way so that the light is off for more than 1.5 seconds, and then let go and it will go to "low" mode.
Pretty cool!
Pretty cool!
