CPFReviews.com: Orb Wee NS ...a Jewellery Adornment!...Runtime Added
ViReN
CPFReviews.com
Orb Wee NS
Provided for review by http://www.lummi.co.uk/
General Description:
Orb Wee NS is an attractive Nickel Silver Flashlight from Lummi. Wee NS is designed as a wearable high power LED flashlight. When worn, Orb Wee NS can easily be mistaken as a Jewellery Adornment. Powered by a very small rechargeable 10180 Li-Ion battery, Wee NS is one of the smallest, brightest and high quality flashlight. Wee NS has Cree XR E, Premium Q4 Bin LED as solid state light source. The Body is built of Nickel Silver, has O-Ring Seals for water resistance. The maximum output is around 50 Lumens. Orb Wee NS has very simple direct drive circuit, this offers very simple yet reliable operation. Orb Wee NS is designed to be one of the first wearable High Power LED (Every Day Carry) EDC light.
Light Features:
  • Premium Q4 Binned Cree XR E LED
  • Wearable as a Jewel
  • Very Small and powerful
  • Solid Nickel Silver Construction
  • Reliable Operation
  • Tritium Locators that will glow for years and years, no charging required!
  • Flat Tail Cap allows 'Candle Mode'
Extreme Closeups:
More...
Update 1: 01/10/2007
Light Info has now been updated/
Runtime;)
The 10180 Li-Ion battery was charged, given rest for 2 hours and then put up on Extreme Tech Hyper Efficient Very Special Runtime Rig :duh2:
Re: CPFReviews.com: Orb Wee NS ...a Jewellery Adornment!
Very nice Pictures, that light is really good looking and small!
Any chance of a runtime test?
thanks
Yes, Sure, I now have a very good light measuring system with me. Will be updating the Database and Update the Runtime chart as well :)
:thumbsup: Massive :thanks:
very nice. Those are the best closeups I've every seen of the wee. I'm looking forward to the runtime tests.
Nice light but I can't find it listed on the Lummi web site?
Runtime;)
Those zoom pictures are amazing! Great review!!! Can you measure the current consumption? I want to buy the same version as you have (with 30 min runtime)... :) By the way, how do you charge the battery? AW, the supplier of the cells, says "use 10-20mA coin cell charger" but where to get these? A standard charger (R123, nano,...) will put way too much current through the cells when charging, so I wonder where to buy a suited charger.
I believe many people are just using the 123 Nano charger without issue.
Dear Erasmus,
Thanks :) ... I have 50 Lumen Version, if you need more runtime, you can go in for a 25 Lumen version... that should last for 1.5 hours :)
I am using 2 Bay Charger from AW with a spacer. most of the time, i charge with 2 cells in parallel to divide the current. Nano for 1AAA should work fine too.
Will measure the current draw today :thumbsup:
On the Y axis in your runtime graph, what unit is used for measuring Total Output?
To get total Estimated Lumens just divide the total output numbers by 10.
Please note Although I get consistent readings, the figures are of estimated lumens and my Extreme Tech Hyper Efficient Very Special Runtime Rig :duh2:(any body wanna see that setup?) has an error factor ranging from 10% +ve or 10% -ve
I just measured the current on a fully charged battery, it's exactly 200 mA ! dot on Lummi's Specification.
What I like about Orb Wee NS is that it is dot on target on Total Output, Runtime and Current Draw.... There is No Marketing Hype, Specifications are right on target. .. this is some thing very less manufacturers practice.
