ViReN
Vencon UBA5 Ultimate Battery Analyzer & Charger
www.vencon.com
General Description:
www.vencon.com
Vencon Ultimate Battery Analyzer UBA5 is professional grade, very versatile, PC controlled, dual channel, battery analyzer, charger and data logger with networking capability. With its extensive flexibility, UBA5 is a single unit that will cater all your battery analysis requirements. UBA5 enables you to virtually test any kind of batteries with any kind of battery chemistries. Be it small button cells, big batteries; Alkaline battery chemistry, NiMH rechargeable batteries (both standard and LSD), NiCd rechargeable batteries to Li-ion & Li-polymer batteries; anything as long as it falls under the acceptable power, voltage and current range of UBA5 can be tested using Ultimate Battery Analyzer UBA5.
The first UBA version was introduced in 1992; back then, UBA was the first low cost PC controlled battery analyzer in the world. Introduced in 2007 with multiple enhancements and improved capacity, UBA5 is fifth and latest revision of the legendary (Ultimate Battery Analyzer & Charger) UBA Architecture. UBA5 is a result of more than 15 years of extensive analysis, study, continues research and evolution of the UBA series. Notably, Marc Venis, founder of Vencon Technologies, built his first automated analyzer in 1981. The latest UBA5 easily caters needs for the most advanced and demanding battery users. Be it for military equipment batteries, medical equipment batteries, RC enthusiasts, Flashlight enthusiasts, battery manufacturers, caver's, divers you name it UBA5 has got everyone covered.
Anyone who needs to ensure that their batteries perform with utmost reliability must have UBA5 for the ultimate analysis and testing. UBA5 console software offers unlimited potential and flexibility to engineers & researchers for testing multiple types of batteries simultaneously. With networking features of UBA5 and UBA5 Console Software, You can connect many UBA Analyzers together, the possibilities are endless. Best of all, Single Console Software controls ALL the UBA's in the network. UBA5 is available in various configurations and combinations including UBA combo packs. You also can order custom configuration directly at www.vencon.com. A host of accessories such as temperature probes, external loads, relays, etc. are readily available. Vencon, a company with a team of highly experienced professionals is dedicated to offer the very best in terms of product options, technical help & customer support. Reviewed here is the UBA5 General Purpose (GP) Combo Pack. UBA5 GP Combo Pack includes UBA5, Software installation CD, 19 Volts 4.5 Amp universal power supply, serial & battery cables and operating manual.
Vencon UBA5 Ultimate Battery Analyzer & Charger (UBA5 GP):The first UBA version was introduced in 1992; back then, UBA was the first low cost PC controlled battery analyzer in the world. Introduced in 2007 with multiple enhancements and improved capacity, UBA5 is fifth and latest revision of the legendary (Ultimate Battery Analyzer & Charger) UBA Architecture. UBA5 is a result of more than 15 years of extensive analysis, study, continues research and evolution of the UBA series. Notably, Marc Venis, founder of Vencon Technologies, built his first automated analyzer in 1981. The latest UBA5 easily caters needs for the most advanced and demanding battery users. Be it for military equipment batteries, medical equipment batteries, RC enthusiasts, Flashlight enthusiasts, battery manufacturers, caver's, divers you name it UBA5 has got everyone covered.
UBA5 Technical Specifications:
Pictures:- Batteries Supported: All types of primary & secondary batteries. Primaries including Carbon Zinc, Alkaline, Primary Lithium, Silver Oxide etc. Secondary batteries including NiMH, NiCd, Gell Cells, Lead Acid, Lithium-ion and and Lithium Polymer batteries. UBA5 can accept Single cells or battery packs either in series or a combination series parallel cells.
- Battery Voltage: Ranging from 0 to 18 Volts.
- Battery Capacity: 20 mAh to 120 Ah or more
- Internal Load: Two electronic loads, one per channel
- Internal Load Type: Programmable, Constant Current/Constant Voltage
- Internal Load Current Capacity: 12 mA to 3000 mA in 12 mA increments. Power capacity limit of 45 Watts per channel.
- Internal Load Accuracy: 0.5% reading ± 2mA
- Internal Load Resolution: 0.1 mAh
- Load Cycle Termination: Cutoff Voltage, maximum time, maximum capacity, any combination of maximum time and / or capacity, temperature termination with optional temperature probes.
- Internal Charger: Two, one per channel
- Internal Charger Current Capacity: 20 mA to 2.0 Amp in 20mA increments.
- Charge Termination: Peak (delta V), maximum time, charged capacity, any combination of maximum time and / or charged capacity; temperature limit, dT/dt with optional temperature probes.
- Power Input: DC, accepts 15V to 26V, 4.5 Amp max current input
- Battery Input: Two pairs, banana connectors
- Ports: Two, Standard 9 pin RS232 connectors, one male, one female
- Other Ports: Total Four Accessory input output ports. Two programmable digital outputs and two analog inputs
- Input Protection: All inputs and outputs are reverse polarity protected
- Other Protection: Internal temperature sensor
- Indicators: 3 LED, 2 Red for battery, 1 green for power
- Size: 130mm x 170mm x 75mm (WxLxH)
- Weight: 820 gm
- UBA Console can control multiple UBA's simultaneously
- UBA Console has professional graphical & visual user interface
- Excellent context help and online manual
- Built in Tools: UBA Network Viewer, Battery Analysis Routine Designer, Battery Analysis Results Viewer
- Database Tools: View Battery Database, Add / Edit Battery Database, Find Battery Wizard
- Software Compatibility: Win9X/NT4/2000/XP/Vista/Linux-Wine
Vencon UBA5: The UBA5 Ultimate Battery Analyzer & Charger package includes the UBA5 pictured below with host of other accessories. UBA5 is a small box with electronic goodies packed inside. Externally the box measures 130 mm in width, 170 mm in length and about 75 mm in height. The box has a beautiful black colored anodized matt finish. All labels over the box are printed in bright yellow color making it easy to look and clear to identify. On top of the box you will notice square shaped attractive design created by a combination of circular and rounded wide rectangular perforations placed for easy airflow. Just below the perforations, you can see through a cooling fan installed for forced air cooling. The temperature controlled variable speed cooling fan dissipates heat generated during high current charge and discharge.
Jump To: Description - UBA5 Features - Pictures - Safety Instructions - UBA Console Software - Tests - Applications - The Verdict
