jdhunter
I'm a development engineer for a fiberoptics applications company. Our pioneer LED product is basically a high-end LD flashlight with a port to receive the input post of a fiberoptic scope for looking around in body cavities with. The engine is a LUX III and one of Wayne's DownBoy (now Son Of Badboy) converters built to provide 611 milliV. It's powered with two CR123A primary cells. Naturally we use and resell the cheapo variety available from www sources for 99 cents (we wrap our own label around them.) We've just had an incident with them in the shop.
One unit in production wasn't working reliably. (I now presume it probably had some intermittent dead short.) While it was in a won't-work mood the technician lost track of whether the clickie was on or off and set it aside - in the tub with other product in bubblewrap baggies. Some time (10?, 15?, 20? minutes) later there was some noise (hiss?) and smoke from burning plastic (the baggie) and then a bang with flame. Techie swatted the fire out.
Post mortem: the battery to the rear was incinerated and the bottom bulged, the tailcap switch was deformed, charred and partially extruded. The forward battery though singed still has 3+ Volts!
I cut the burned battery apart. I found: pressure relief valve body full of slag, black powder, aluminum mesh, center anode... I was sort of looking for the protective electronics which I understand from the general literature is supposed to be the magic stabilizing influence to civilize these things. I don't see anything that looks like any electronic component in the remains.
SO, my questions to the forum are, does anybody know just what form the protection electronics takes and where is it in the structure of the cell? And, of course, is it an unfortunate fact of commercial life that the China cheapies (Tenergy, Powerizer are the two names I've seen in our stock) omit the feature and hope for the best? Does anyone know of a cutaway diagram that truly gets into design details?
Thank you.
J. D. Hunter
Thank you.
J. D. Hunter
