DocArnie said:If I can follow you, do you mean that it might be possible that the tailcap was tightened for constant xenon-light? I can assure that this wasn't the case.
I wouldn't dismiss this possibility so quickly. It would be VERY easy to miss LED tail cap being in the incan "Continuous ON" position with batteries low enough that they don't activate the incandescent lamp.
The only indication of this scenario would be that NO lamps illuminate w/switch activation as the switch is already beyond the LED "Continuous ON" position. Incidentally this indication is the same as when the tail cap is locked out or dead/no batts are installed. Not a good situation as the circuit is complete and easily mistaken for a "safe" position.
The only low batt "safe" indication with this rig would be to verify the LEDs activate then back off the LED tail cap until depressing the switch will not activate the LEDs. This is similar to a LOTC (Lock Out Tail Cap) safe position.
The above is my opinion only and not intended as critique of any sort. Just sounding out possibilities. Glad no one was injured.
G36pilot
