Crazy idea for Public Art piece, Help!
federico muelas
Hi Everyone,
Here is a crazy idea… I’m doing a public art piece Titled “Blue Flower/ Flor Azul” for the new School of Architecture in Albuquerque. On this piece I’m projecting the image of a drop of ink against an outside wall in the building, the image is 28’ diameter, and…this is the key… I’m using a water tank and real ink on the site… to make it more complicated this is a permanent piece, expected to work for twenty years!
This is based in an old piece of mine called “Dripping sounds” , but at a gigantic scale (you can see both projects in my web www.federicomuelas.com
Ok… to project the image I have to options, one… making a custom made projector incorporating a powerful light, condenser lenses, the water container (with all the stuff to control the dripping of ink) and two achromatic lenses. Option two… get the image of the ink with a HD video camera and project the image against the wall with two stacked 15,000 lumens Sanyo projectors. I rather prefer the first option, first because the second idea is too expensive and secondly because, using a super powerful light source I could achieve any lumens I want.
But I abandoned the idea of the custom made projector over the Sanyo projector when I start dealing with HMI lights, too much current, too much heat, too short lifespan… too many problems… Until this friend of mine showed me the Titan Light engines.
But the truth is that I’m not sure how this LED lights will work on projection systems, I know they are used for illumination on building, but projecting systems?
Tips? Ideas?
Thanks guys
Federico
Why not consider hanging an LED "curtain display" on the side of the building. Feed your image from the camera to the LED display. The technology is available from quite a few vendors (for rent or purchase) and in many resolutions, and the piece could be bright enough to be visible in daylight, if desired. I don't think you will get enough lumens out of an LED source to project an image that large and have it be very visible in anything but complete darkness, and no city is completely dark at night.
Federico, you need a drawing to follow your words.
Fellas, this was taken from Federico's website:
You're right skiendog, an image is needed, thanks for posting it!
we were thinking on the LED screen mahoney, but at that size it would be tooo expensive, and hard to control. also there something poetic about just light, water and lenses... but pain in the neck.
thanks guys!
f
Welcome to CPF, frederico :)
Interesting project... I'm not sure it belongs here in LED Flashlights, but I'll leave it here for a while. We may need to move it to Fixed Lighting at some stage.
Could you resize your pics to 800 x 800 pixels maximum please - see Rule 3.
Federico,
As a BFA industrial design major myself, I understand the difficulty of trying to use only words to communicate concepts and designs... ALL TOO WELL.
