So I have been screwing with some casting materials and trying to find one which can be used as a heat sink.
I have a material which contains alot of aluminum powder and is actually intended to dissipate heat. Now im sure that being it only contains a portion of aluminum that its not as conductive as a true aluminum heatsink. So im curious how hot is too hot for one of these cree leds and how do you check.
I have one of them attached to a piece of the machined casting material with arctic thermal paste and it runs continuous without an issue. However I do notice that the little bugger is HOT
any way or idea how to check if its within operating range. I thought about getting one of those laser thermometer deals but even with that you cant really check the back thermal pad.
ideas????
ideas????
