Good morning
One of my favorite sellers on Ebay started to advertise CREE R2 leds
both as drop in upgrades and new flashlights...The output is listed at 290-300 lumens...
is that true?...anyone got one yet?
bought a couple of R2 drop-ins (may NOT be the same as what you've seen on eBay; i haven't looked on eBay for them) from John at Lighthound.com which arrived a couple of days ago.
one R2 drop-in is single mode to be used with a UNIQ "infinitely variable" tail cap switch; the other R2 drop-in is the five-mode with memory. both are* [see Note below] hosted in SolarForce L2 hosts.
the five mode R2 was bright (talkin' lux or peak brightness at the center of the "spot" here) on HI, but i was really expecting something more. however, it's spill was quite bright also, so, it might have a pretty high lumen value/rating.
i'm going to have to do a side-by-side "eyeball" comparison again.
my first side-by-side of the R2 hosted in a SolarForce L2 with Leef McClicky tailcap (i wanted the tail to be crenelated like the bezel) was to an unmodified SF G2L Nitrolon, two CreeP4 drop-in's and one CreeQ5 drop-in. these were hosted, respectively, in a a black G2L Nitrolon (like i said, unmodified!), a DesertTan SF G2 Nitrolon, a black SF G3 Nitrolon, a black SF G2 Nitrolon (with a SolarForce clickie tailcap).
the CreeQ5 appeared brighter in its center spot to the eye than the R2, but this could be b/c of the diff. in relfectors with the Q5 having a smooth reflector (complete w/classic Cree donuts and rings) while the R2 had a LOP/textured reflector. overall, the R2 looked brighter than the Q5 once one looked outside of the bright hotspot to the spillbeam area. the R2 also had a larger diameter hotspot than the Q5.
the only thing quantitative (since i don't yet own a light meter) i can say about them is the current draws (wait until you read the Q5)[anyone, please let me know how these numbers compare with other numbers that you've either seen or measured - i didn't dig out my old, but working Fluke for this, and instead used an old top-o-the-line, which ain't sayin' much, $60 RadioShack DMM to perform the current measurements]. oh,...fresh SF CR123A cells were used for the testing - each light gettin' fresh cells which max'd out the %SOC lights on a ZTS MB-1 tester and tested within 0.05VDC of each other on a DMM.
[NOTE: to really determine more accurate readings, i would have to place each drop-in in the exact same identical host, and make several disassembly-reassembly tests of each drop-in to take into account any inherent resistance in the host and any resistance that my manner of assembly contributed, and then average the current readings for five runs for each drop-in with disassembly and reassembly between each run for each drop-in. i didn't take the time to do this.]
stock/unmodified SF G2L Nitrolon = 400ma [the de facto standard]
CreeP4 (Mfr. claim of 750ma) in the DesertTan SF G2 Nitrolon host = 570ma
CreeP4 (Mfr. claim of 750ma) in the black SF G3 Nitrolon host = 450ma [hopefully, burn-time will be longer than in a 2-cell application]
SolarForce L2 host with a Leef McClicky tailcap having a SolarForce LC-5 five mode with memory Cree R2 drop-in: Lo=140ma, Med=360ma, Hi=700ma
five mode with memory CreeQ5 drop-in in a black SF G2 Nitrolon with a SolarForce clickie tailcap: Lo=390ma, Med=910ma, Hi=1510ma (wowzer's!!! [if it's accurate]).
Note:
*the second L2 host which is intended to host the single-mode R2 (already in hand) arrives via USPS Priority Mail today, so i haven't yet put the single-mode R2 drop-in in a host yet.
