Re: Cree Stainless Steel reviewed.
FYI:
Glass lens is 17,5mmx1,8mm, plastic reflector is 17,8mmx10,4mm, circuit board is 16,8mm dia, components are 8530-36184 labeled chip, SS14 diode, inductor of unknown value.
The Cree XR-E is floating 1,3mm over the base in the head, there is absolutely no thermal contact to the head or body of the light!!!
There is no o-ring between the lens and the bezel.
I rate the construction zero points.
@x2x3x2: you may use my pics posted in the other thread, if they are any good...
