Cree released this road map for the XRE many years ago. The R4 & R3 bin is unobtanium. The R2 bin is in limited supply. The Q5 bin is more commonly used. Many flashlights are still using as low as P4 bin.
To get 164 lumen with an XM, Cree needs only 41 lumen per mm^2. 2mm*2mm die.
To get 164 lumen with an XPG, Cree needs 82 lumen per mm^2. 1.4mm*1.4mm die.
The maximum power driven to the XM-L will be limited to the thermal transfer from the LED to the heat sink.
The transfer area on the XM is much smaller than the MC or the P7. That means a more concentrated point of
heat that must be dispersed. We are able to do that with the SST-50 and the SST-90 by soldering an 8-32 brass
screw to the LED, and then using thermal paste when screwing the LED assembly into the the heat sink. Getting
rid of the heat from the XM will be a challenge at high drive currents because of its small size.
Curt
Isn't it an old pdf that has never been updated since 2008 ?The XRE officially only goes up to Q5 now.
I think you meant lower lumens per mm², at least judging by the content of the rest of your post. Other than that, good post and I agree completely. Fixed lighting and backlighting is really where it's at for LED these days, and in those applications the longer the life the better.Lower lumens per watt is not a bad thing. It means the LED is underdriven and will last longer. The Luxeon IV was only rated 500 hours but I have not seen a single complaint of a Surefire L4/KL4's dead LED. But if you try to sell an LED household bulb that lasts only 500 hours you won't be in business for long.
Remember that the XP-G was originally rated at 1 amp by Cree but in my tests it had no problem handling in excess of 2.5 amps. The XM-L will likely be able to handle 5+ amps with no problem, although of course it will be pointless to drive it past where the output stops increasing. As usual, once I get my hands on one I'll be happy to test it to its limits and report my findings. Cree's ratings have more to do with prolonging life than with the limits of what the LED can physically handle.I would expect that Cree will raise the maximum recommended current for XM-L after more testing (3A?). They did the same thing with XR-E, XP-E, XP-G...
I would even bet that XM-L @ 3A will be as bright or brighter than SST-50 @ 5A.
From what I understand, the R5 is a 1.4mm chip, and the S2/S3 is a 2mm chip.
