Custom Led lighting
trafton
I am going to wire 3 leds in a series at 350ma. Using a led driver such as http://www.instructables.com/id/Power-LED-s---simplest-light-with-constant-current/
I will be using an ac to dc adaptor before the led driver.
I want to control it with an illuminated metal switch such as http://langir.en.made-in-china.com/product/xeaEhjsvhkcJ/China-Illuminated-Vandalproof-Push-Button-Switch-L16-L19-L22-L25-.html
How would I wire the led in the switch to illuminate it? Since the led is different and is prob just a small led that has a different current draw and Vf then the 3 high power leds drawing 350ma.
Hi,
it looks to me that you specify what voltage led in the switch you require "LED voltage: 3V, 6V, 12V, 24V, 110V, 220V" and supply it with your chosen voltage.
