Update:
I have started another round of cycle testing.
Since Eneloop cells have become very popular, and there have been some discussions on fast versus slow charging of them, I decided to see what the effect of fast charging on them is.
I have modified the test procedure, a little, to single out the effect of fast charging.
With this test I am charging on the Energizer 15 minute charger, until the fan stops. I then rest the cells for 30 minutes before discharging them. This time, I am using a 1 amp discharge rate. I don't think a 1C discharge rate is hard on a cell, but by limiting the discharge rate to 0.5C, I can minimize this variable.
Other than the change in discharge rate, this test will be very similar to the test using the Titanium 2000 mAh cells.
Does anyone care to venture a guess on what will happen?
I will give you a hint... after the first 25 cycles, the capacity of cycle 25 was about 99% of the capacity of cycle 1.
Tom
