yaesumofo
OK guys when I decided to buy a D10 is was mainly because of the PD design element. I like Don's Pd's a lot and am interested in the implementation of them in new lights even if they are made off shore.
That said.
The D-10 is a AA light.
I bought a very expensive Lithium cell 14500 for the light.
The thing is it has a very LOW capacity when compared to a NiMh cell.
the lithium cell is a 3.7 volt 750ma cell for 2.775 WH
some of my aa cells are 1.2 volt 2800ma cells for 3.36 WH
It would seem to me that a hi capacity NIMH cell would give a little more runtime. and cost a lot less.
Does the circuit in the D10 deal with 3.7 volts better than 1.2 Volts?
How efficient is it?
Have you guys noticed that the light is brighter with different batteries?
Some of this stuff may be covered in the manual but I am not sure I totally trust the factory to be completely exact in their specifications. They do have an interest in making the numbers look good.
ON the whole I like the D10. one thing I don't like is the constant draw. I can't see any good reason for this.
ON to the O-ring.
Unfortunately I lost my spare O-ring pack. I requested a replacement and 4x7's sent me a second accessory pack. (thanks guys) The thing is the O-rings which came with the light and the units sent as spares are totally different with the units mounted in the light being RED/orange and the spares being clear.
Just for kicks I mounted a clear O-ring and found the action to be no smoother just a lot easier to turn too easy. I like the stiffness to the twist action when the red O-rings are in use. I think they will be better in keeping out moisture and water too.
What are you guys doing? O-ring with the stock red or switching over to clear? Why?
On the whole I am impressed with the D10. One of my favorite "features"
is the material used to make the light 7075 aluminum. This is TOUGH Stuff. IMHO all of our single cell lights should be made form 7075. It is clearly a superior material to 6061.
I am also impressed by the anodizing on these lights. Normally on aggressive knurling anodizing begins to wear very quickly. So far even in pockets with keys I have not noticed any wear on the finish. It reminds me a lot of the quality of finish on my own MOFO CLICKY. while it is a matte finish unlike my work on that part it holds up just as well. Impressive.
Looking forward to your responses to my questions.
Yaesumofo
That said.
ON to the O-ring.
Yaesumofo
