Damaging concrete with 7075
lion504
Ok, we've seen special metal runs of
- Ti, brass, naval brass, bronze, Ni-Al bronze.
- Bare naked 6061
- Be Cu
What about 7075??? Distressed or HA, she brings a big ol helping of zinc to the table for some serious strength and resistance to deformation. Drop her and she punishes concrete! Colluding to keep her out of the HDS lighting market seems unethical if not illegal in most states (and especially AZ).
I'm buying, who's with me?
Here's something to aid the discussion.
ElectronGuru on Aluminium...
No metal is best at everything so different priorities can lead to different decisions. Here's a quick breakdown on aluminum:
6061 - best corrosion resistance + worst strength + good at finishes
2024 - good corrosion resistance + good strength + good at finishes
7075 - best strength + worst corrosion resistance + bad with finishes like natural ha
So 7 series is a specialist metal, giving up certain benefits to get a single other benefit, strength.
Personally, I don't have a view, just thought I'd drop that one in.
P
And some more data...
7075 vs 6061, Titanium, and Steel
7075 Aluminum
Yield Strength: 73,000psi
Ultimate Tensile Strength: 83,000psi
Shear Strength: 48,000psi
Density: .102 lb/in^3
Grade 5 6AL-4V Titanium
Yield Strength: 128,000psi
Ultimate Tensile Strength: 138,000psi
Shear Strength: 79,800psi
Density: .160 lb/in^3
Grade 5 Alloy Steel
Yield Strength: 92,000psi
Ultimate Tensile Strength: 120,000psi
Shear Strength: 72,000psi
Density: .284 lb/in^3
Grade 8 Alloy Steel
Yield Strength: 130,000 psi
Ultimate Tensile Strength: 150,000psi
Shear Strength: 90,000psi
In terms of strength, stainless steel is in any case stronger than this aluminum. Maybe then made body from same stainless steel as a bezel?
Sounds cool............. however how many have actually damaged a HDS? I guess that is not the real point. I might buy...…………..
