DBS V2 tail cap keeps comming unscrewed on the inside????
fire-stick
Austin Indiana, USA
The last few times I have taken my tail cap off the aluminum metal disk on the inside keeps coming unscrewed.
I tightened it a little with the tip of my knife, but it didn't work so well. Is there a certain tool I should use to tighten it?
After I tighten it will it stop of is there something wrong with it?
Thanks
-Scott
:naughty:
Don't tighten the end cap so tight ... when you change batteries.
That will help some.
It is a common problem .
Don't ruin your knife, do as FireStik said and get some fine needle nose pliers so you can grab both holes and properly tighten it. I don't have any problems with mine coming loss, I tighten it pretty good. :)
I don't tighten it hard just kida snug.. alough I will start putting it on a a little softer..
I'll find a real small set of nedle nose pliers and try that... thanks
