WadeF
Thought I'd comment on some things I've noticed with my Dereelights. Maybe others who have any tips or tricks for their Dereelights can also share.
For those who aren't familiar, Dereelight sells individual pills (pill is the brass heat sink, circuit, and emitter) and reflectors for their lights. This allows you to buy a new pill when a better emitter comes out, or by different pills with different functions. You can also easily swap between OP and smooth reflectors.
The Dereelight CL1H and Dereelight DBS have their own unique pills. What I have found is the DBS pills have the LED more recessed than the CL1H pills. The DBS pills also include an insulating washer around the Cree LED to prevent the contacts on the emitter board from shorting out against the reflector. This has happened to me (when experiementing) and so far it hasn't seemed to damage anything, but the pill will fail to light.
Now, the CL1H pill's LED sticks out more. I have found you can gain a bit of throw in the DBS by putting a CL1H pill in it. However, the CL1H pills do no have an insulated washer and can short agains the DBS reflector. The CL1H reflectors have an insulating washer on the rear of the reflector, so one isn't needed on the pill. So you can either make a insulated washer, or if you have a spare CL1H reflector you can pop off the insulating washer and stick it on the back of the DBS reflector. Then you can screw in the CL1H pill into the DBS reflector and you may find you can get the LED deeper into the reflector which should result in a tighter hot spot. It's handy to have a LUX meter to take readings.
The other thing you can do is focus the LED's. I find with my DBS the tighter the better. However, with my CL1H I found if I backed the LED out a little bit, about a turn, I gained over 1,000LUX in the hot spot (with a smooth reflector) on my LUX meter! So I with the pill fully tight I was getting around 8,300LUX, and with the pill backed off a bit I was getting 9,700LUX!
So if you have some extra Dereelight pills and reflectors it's worth trying different combinations to see which gives you the best result.
I could possible fine tune my CL1H pill even more, but I'm pretty happy with the way the beam and hot spot look, and the intensity of the hot spot.
