i have 3 designs:
Design 1:
something puck shaped about 4cm across and 1cm thick, with a big green button on the top. when you press the button the thing softly glows and illuminates everything for a mile around, with an abrupt end to the light after said mile. its charged by placing near a WI-FI device, and for every 5 seconds it is within 1 meter of said WIFI device it lasts for 12 hours. no limit to how much juice it can store.
Design Two:
About the size of a standard USB memory stick, with rounded ends and a USB port in the back. one small-ish red button on the top near the front. press the button and it projects a menu of functions accessible by more button presses. charged by USB, similar to above unit, 5 seconds of charging gives it 4 hours of runtime. no limit to how long it can last.
design 3:
size of Hotbeam's Pocketmate-W, with 500w of pure LED power out the front, and a logarithmic 10-turn dial in front of the button. output ranges from 0.5w to 500w (duh)
plugs in to mains to charge (take off tailcap and extend 1.5m mains lead). like above, 5 seconds of charging gives 1 hour of runtime at 500w output. no limit to how much juice it can hold. shoots out so many photons so fast that, if placed upside down, will lift off and in the course of 15 seconds lift 6 feet in the air.also, a prickerator that makes the thing act exactly like a lightsaber, only its 15 miles long max, with length adjustable by the Supa Smartdial /ubbthreads/images/graemlins/smile.gif /ubbthreads/images/graemlins/wink.gif /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/smile.gif
also, charge any of the above in for a month, and they will run continous for longer than you will live /ubbthreads/images/graemlins/smile.gif
colours? all black with white light excepting the coloured buttons.
finish? umm, entire thing made of Unobtainium..... think the hardness/durability of a diamond times 5 million /ubbthreads/images/graemlins/smile.gif also everything is infinitely stretchable. moldable like putty. only limit is the key tailcap and a 1 inch hole (light output) for D3, the button for D1 and the button, USB plug and a 5mm hole for D2.
/ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/grin.gif
WHOOP WHOOP
neg
