BrianMc
- Joined
- Nov 4, 2009
- Messages
- 940
Funny, it looks like a film cannister with two or three LEDs inside to me. Aluminium lid to shed some heat...
Might give it a try and clone it :devil:
It appears to be longer with the LEDs arranged linearly down its center (pictures from their web site copied to a service to avoid hot linking, but as this is not a commercial use, and having the cycling community familiar with the aftablasta, I think it fair use):
It looks like a linear array of red LEDs down the center line, and a cover a bit longer and wider than a film cannister.
That said, a film cannister bottom fits the bezel of the Bullet Marwi light body perfectly. And it just so happens two of those NOS lights should be delivered today one for spares, the other as a possible host for a driver and red LED board. :naughty:
I could stick with a triple MCPCB and aim the light straight back with the frosted translucent 'lens' like the earlier red flashlight extension difusing the light to the sides. Stick in a bFlex to match the front lights to keep programming the same (easier for me to keep straight) and for reliability, as it is a safety device. That would be straight forward and I would likely go the aluminum slug route as a firewall/thermal path to the aluminum body.
OR I could mimic their design more closely. The LEDs are cheaper on three 10 mm square or round MCPCB's and I could mount them on a spar fastened at one end and side to the body of the light with the three 10 mm PCPCB's side by next on the other side and end of the spar facing what would have been the top of the light. The cannister is 50 mm long, so the first LED could be 15 mm from the edge of the bezel and the last 15 mm from the end of the film cannister.
Full on, I would be moving 3 watts of heat or so down the spar to be radiated by the body. The spar needs to be 10 mm wide for the MCPCBs, and at least 5 mm thick at the LEDs. I think it will be "L" shaped so it connects top and bottom of the light body and side struts at 90 degree to place it laterally in the body, increase its rigidity, and improve its thermal path to the body. Does it need to be thicker than 5 mm ( 50 mm cross section) to be adequate to handle 3 watts?
